Breaking encryptioni
scanmanmi
Central Michigan
#1
I know nothing of how encryption is done. I know there is a key (128 bit?). If a system has a single non-changing key why can't it be broken? Wouldn't you just try a number, wait for a transmission, change it if didn't work? If you had a key is there any scanner that could use it somehow
marcotor
Sunny SoCal
#2
Here's the number of keys you will need to try:
115,792,089,237,316,195,423,570,985,008,687,907,853,269,984,665,640,564,039,457,584,007,913,129,639,936
Happy hunting :)
SteveSimpkin
Lancaster, CA
#3
You missed your chance. April Fools day was yesterday:)
krokus
Southeastern Michigan
#7
For some timelines, check how long cracking a 72 bit key has taken.
https://en.m.wikipedia.org/wiki/Distributed.net
Sent using Tapatalk
ladn
Southern California
#12
This has been hashed pretty well, but I'll add my $0.02 anyway. Back in the old days of analog inversion encryption (still used on some CCR's), you could step through the various encryption iterations. As you got closer to actual decryption, the voice would get more intelligible until it was completely in the clear.
There were even some aftermarket products designed for the "hobby" market to decode analog inversion encryption. These worked because there weren't that many possible key combinations.
Digital encryption changed everything because of the massive number of non-related possible keys. In your example, could a static 128 bit key be broken? Yes, given enough computing power and time. Sometimes there are back doors and mathematical shortcuts. The folks at Fort Meade would know far more about this than I, but for the average user, consider digital encryption to be unbreakable.
PA
#14
Well-designed encryption algorithms aren't like that. If you guess even one key bit wrong, the output is mathematically indistinguishable from random static, the same as any other wrong guess. That's what makes encryption unbreakable, at least with any known practical analysis methods. AES has some theoretical attacks, but some of them require more storage space than currently exists on earth, so they aren't very practical.
UPMan
Uniden Representative
Arlington, TX
#15
Voice inversion isn't really encryption. It is essentially the same as tuning to the wrong sideband in SSB. Recovering the audio is fairly trivial.
wa8pyr
Technischer Guru
Moderator
Ohio
#18
Voice Inversion is not considered encryption. It is legal to use.
But, since the purpose of voice inversion is to render the content of the transmission unintelligible in order to prevent unauthorized monitoring, I suspect the law may look at it differently.
I don't think it's ever been tested in a court case, but I wouldn't think it worthwhile to be that test case. . . . .
UPMan
Arlington, TX
#19
There is a legal definition of encryption. Typical voice inversion does not meet the legal definition. We have had this discussion with a government agency, before (not in court, but not far short of it).
jasonhouk
Marion, Ohio
#20
Want to break encryption? All you have to have is access to WindsorGreen. Ole and to get that you'd probably need to be working for the NSA.
Houk
