Bricked SDR?
hockeyref2
Northern MI
Hello,
I have an RTL-SDR v3. I used RelWithDebInfo (rtl_eeprom) to attempt to change the serial # of the receiver... The drivers seem to be installed properly but the SDR is now not seen with rtl_test, unitrunker or SDR#.
ZADIG shows a "RTL2838UHIDIR" device with WinUSB 6.1 drivers installed. I have tried reinstalling drivers several times. Rebooting etc. Even tried it on a different PC that has never had a SDR on it. At one point, it was showing "bulk-in interface 0" and "bulk-in interface 1" at the same time in both zadig and device manager....
I uninstalled in device manager, and reinstalled drivers multiple times.
If I run RTL_TEST, it just says no devices....
Any thoughts on what to try, or what to look at to get it working again?
Thanks!
boatbod
Talbot Co, MD
Had this happen to me once. Luckily I was able to use the same utility to read the config out of another rtl device and then write it back in to the "bricked" device. Worked like a charm after that.
hockeyref2
Northern MI
Ugh, that sucks. Does it show up with 'lsusb'?
Actually yes.... to an extent..
pi@raspberrypi:/etc $ lsusb
Bus 001 Device 005: ID 00a0:2838
In comparison, my flightaware pro says Bus 001 Device 006: ID 0bda:2832 Realtek Semiconductor Corp. RTL2832U DVB-T
Any other thoughts? I already ordered a new one, but it would be nice if I could get it working again. Thanks for your help!
boatbod
Talbot Co, MD
So rtl_eeprom does not see the device at all? When I bricked mine I was fortunately still able to access it with rtl_eeprom even though the kernel couldn't load the proper driver.
