FG3 is still wrong in the database apparently.
Bridgeport is also licensed for 154.415 (2 bases and 105 mobiles) but I dont see that in the database.
173.3125 is licensed for station alerting per the FCC ULS, but that is not listed in the RR Database.
No PD Ch 3 is listed.
PD Ch 4 shows as 2 different channels.
FCC ULS shows FD Tac 6 thru 9 as mobiles or portables only - no bases.
FCC ULS shows Public Works as 158.82 R with 155.67 input. Anyone have a PL?
FCC ULS also shows 39.40 R output.
"Bridgeport Port" shows 158.9925 for security. Anyone have a PL.
All other freqs in the Radio Reference Database do match the FCC ULS for Bridgeport.
Bridgeport is also licensed for 100 MOI (2 watts each) on 769.05625, 769.06875, etc - they might be mutual aid channels.
154.415 is not used as its used alot on long island and is to noisy.
the 173 channel is not used
Bridgeport PD 3 is Detectives 24/7 encryption
CH 4 has been 153.9725 for 4 years at least 24/7 encryption
PD 5 is narcotics 24/7 encryption
FD tac 6-9 dont have bases
Public works is DPL 244
39.4 is the old PD about 15 years ago
Port 158.9925 is NAC 250 but is used like 10 times a year, the port athority boats use the PD channels 95% of the time
700mhz channels are SWAT encrypted
Many people try to update the Database but if you provide good info and they update it someone provides crap 3 months later and they change it, so its no use.
