Bridgwater PW
helix512
Bridgewater NS
#1
I have a Pro-106 Scanner and I am having a problem with on of the freq. Bridgewater Public Works this 165.58500 is the Freq that say I should use but it will not let me use it. the scanner sets up the freq to be 165.57500 or 165.58750 and all I get is off freq garbage. can anyone help please
Fortunately, GA
#2
If you are using programming software, I use Win500, there is on the Extended setting screen area to use FlexStep, click and put a check mark there. It will allow you to program in the proper frequency.
Larry
Taxachusetts
#3
Looks like it's trying to use the USA Band Plan vs the Canadian
