Broadcastify Calls unknown talkgroups restricted access
sonm10
Central MN Monitor
Sauk Centre, Minnesota
I routinely use the Broadcastify Calls to check for unknown talkgroups. This morning I get
"This Group ID can only be accessed by system broadcaster or an admin" on all unknown talkgroups. What's up with this? System is Minnesota's ARMER, btw.
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
I don't recall if it was always like what you describe or not. But I will say it makes sense. Any number of those unknown talkgroups could be sensitive HIPPA / surveillance / etc talkgroups that shouldnt' be provided to the public via the platform. It would make sense to me that they were not available for a non-Calls provider to listen to. Even Calls providers likely can't listen to unknown talkgroups outside of systems that they actually provide a Calls feed for.
bamx2
Indiana
Can confirm, I can only listen to unknown talkgroups on my node.
KD8FSJ
Ann Arbor, MI
Bummer. I've been able to find a lot of new talkgroups and fix a lot of talkgroups in the DB using this mode. There is still a lot of talkgroups that go against the TOS. Some because they are misidentified. Some because the have a generic name. Some because they haven't been noticed.
Ronaldski
MI DB Admin
Bay City MI
I run an Ohio MARCS BCFY Calls node. I can listen to any unknown talkgroup on the Ohio MARCS system
We are admins on the calls is why, appears for whatever reason there was a change and the others can not.
Deziel0495
PEI/NB Database Guy
PEI
Any chance we can add these unknown groups to a personal playlist?
You can with the new "manual add group" feature:
