Broken Arrow System Help Wide/Scat
drkatzjr
I use a BCD396XT, and when programming this system, it first asks me
WIDE/NARROW
SCAT
These are two options. Which do I select for this system?
Thanks!
Tulsa
SCAT = Single Channel Autonomous Trunking a feature that allows a single channel repeater to function as a part of a larger EDACS trunked system, used in low traffic areas. In this case set to off.
