Broward County Sheriff and Fire Rescue
Scanner-geek
Hello. Is there anyone who has an updated list of BSO and fire rescue talk groups? I am most interested in the BSO dispatch and operations talk groups with specifics on the districts covered for each talk group, and the towns/areas in each district. The radioreference listing has some holes in it which I can't figure out. For example, Dispatch 1 and Dispatch 2 are listed without corresponding districts. There also seems to be some discrepancies in the district numeric list they provide when comparing with other sites. The map provided at the BSO web site has no district numbers on it.
If the radioreference list is in fact correct, what are dispatch 1 and 2 and what areas do they cover?
I do understand that BSO handles dispatch for municipal police departments in the county in addition to the areas covered by BSO.
I am trying to understand what talk groups cover what towns/areas of Broward County and it is quite confusing. What I am really looking for in BSO is:
1) dispatch talk groups
2) districts covered on those talk-groups (BSO and municipal)
3) towns/areas covered by a given district
With regard to Fire Rescue I have 3 questions. I undertand there are 4 dispatch areas (North, East, West and South).
1) Are all runs (fire duty and EMS) disptached over the air?
2) Are all EMS runs dispatched over the air on the same fire dispatch talkgroups?
3) When was the Broward county EMS (and those cool squads they had about 20 years ago) disbanded or handed over to Fire Rescue?
Thanks in advance. Looking forward to a trip to Broward--great scanning. It's been two years since I've been down there and it's hard to figure these things out when things have changed a lot and you can't listen yet. I'd like to be programmed correctly on arrival!
Scanner-geek
Scanner-geek
I am also interested in any special-ops type talk groups (bomb squd, SWAT,detectives etc.) Thanks
W4KRR
Coconut Creek
Scanner-geek
Do you have the ability to read an Excel spreadsheet? If so, PM me and I can send you an Excel spreadsheet with most of the Broward County talkgroups on it. I also have one that lists all of the county fire stations and their locations.
To answer some of your questions:
BSO dispatch 1 (4112) is Stockade/detention deputies and prisioner transport.
BSO dispatch 2 (4144) is Community service aides.
The Broward County Sheriff's Office has taken over Broward County Fire/Rescue. It's now known as Broward Sheriff's Fire/Rescue. They have dispatch north (8208), dispatch south (8272), and dispatch west (9232). All Broward County fire/rescue units work from the north channel (8208) regardless of where in the county they are located. On the south channel (8272) you will find Davie and Hallandale, as these cities have their own fire departments and aren't part of Broward County fire/rescue. On the west channel (9232) you will find Oakland Park, Tamarac, Lauderhill, Lauderdale Lakes, and North Lauderdale. There have been some recent changes, so I may be overlooking a couple here and there.
Yes, all fire and EMS calls are dispatched over the air on the same talkgroups. A "working" fire or incident will usually be assigned a "TAC" channel, usually tac alpha (8496), tac bravo (8528), or tac charlie (8560).
Scanner-geek
Thanks very much, Ken. That is very helpful.
So is the Fire "central" talk group 8240 listed at radioreference not in use? Also, do you know which BSO talkgroup covers the airport?
Thanks again!
Scanner-geek
W4KRR
Coconut Creek
Thanks again!
Scanner-geek
Correct, the "central" fire/rescue talkgroup is not in use. Never has been as far as I know. The BSO talkgroup covering the airport is 4592, which is their channel 2B. Airport operations (not BSO) can be found on 12400.
FTLAUD
Wanka
BSO's Central Fire talkgroup was in use when Fort Lauderdale Fire Rescue operated off of 3F on the Broward County system, and were dispatched by Broward County. In 1998, FLFR transitioned over to the city's own radio system with their own dispatchers, leaving the talkgroup no longer in use. In BSO Fire radios 3F will still be FLFR dispatch, however obviously the radio is tuned to a Fort Lauderdale radio system talkgroup and channels.
W4KRR
Coconut Creek
Yes that's true, but the listing for the Broward County "Central" talkgroup (8240 decimal) has either never been used, or was used very early on and then dropped in favor of the configuration that you have mentioned.
Hi, you both seem to have alot of info on the trunk ID for BSO.
Wondering if you can decode this for me? I see them on the radioref section for BSO , but they dont list what they mean? I managed to get the citys main dispatch channels, but I was looking for the car to car for each city, and what (SPPur12G,Super K,C.I. 1) all stand for?
ezy
4112 Stockade/detenti Off Off Auto Dispatch 1
4144 Community servic Off Off Auto Dispatch 2
4176 DANIA/PORT/W.PAR Off Off Auto Dispatch 3 - Districts 1_ 2_ 14
4208 PEMPARK/HALLDALE Off Off Auto Dispatch 4 - Districts 19_ 28
4240 DAVE/COOP/WESTON Off Off Auto Dispatch 5 - Districts 8_ 21_ 16
4272 Ch. 2H Off Off Auto Ch. 2H
4304 OAKLAND PARK Off Off Auto Dispatch 6 - Districts 5_ 12
4368 TAMRAC/PARK/NLAU Off Off Auto Dispatch 7 - Districts 4_ 7_ 15
4400 DEERFIELD Off Off Auto Dispatch 8 - Districts 13_ 10_ 2
4432 PEMBROKE PINES Off Off Auto Dispatch 9 - District 25
4464 MIRAMAR Off Off Auto Dispatch 10 - District 23
4560 INTERNAL AFFAIRS Off Off Auto
4592 FT INTL AIRPORT Off Off Auto
4624 Tac 3B Off Off Auto
4656 KEN JENNE Off Off Auto
4688 Dist 3 Off Off Auto
4720 Tac 4B Off Off Auto
4784 TELETYPE CHARLIE Off Off Auto
4816 TELETYPE DELTA Off Off Auto
4912 Tac 3E Off Off Auto
4944 NARCOTICS SOUTH Off Off Auto
4528 NARCOTICS NORTH Off Off Auto
4976 Tac 4E Off Off Auto
5008 Tac 5B Off Off Auto
5040 LAUDERHILL/LAKES Off Off Auto
5072 Tac 7B Off Off Auto
5104 Tac 8B Off Off Auto
5136 Tac 9B Off Off Auto
5168 Tac 10B Off Off Auto
5232 Tac F Comm Off Off Auto
5264 Tac 5E Off Off Auto
5296 Tac 6E Off Off Auto
5328 Tac 7E Off Off Auto
5360 Tac 8E Off Off Auto
5392 Tac 9E Off Off Auto
5424 Tac 10E Off Off Auto
5488 SP Tac 3G Off Off Auto
5520 SP Tac 4G Off Off Auto
5552 SP Tac 5G Off Off Auto
5584 SP Tac 6G Off Off Auto
5616 SP Tac 7G Off Off Auto
5648 SP Tac 8G Off Off Auto
5680 SP Tac 9G Off Off Auto
5712 SP Tac 10G Off Off Auto
5744 Tac J Comm Off Off Auto
5776 SP Tac 3H Off Off Auto
5808 SP Tac 4H Off Off Auto
5840 SP Tac 5H Off Off Auto
5872 SP Tac 6H Off Off Auto
5904 SP Tac 7H Off Off Auto
5936 SP Tac 8H Off Off Auto
5968 SP Tac 9H Off Off Auto
6000 SP Tac 10H Off Off Auto
6032 C.I. 1 Off Off Auto
6064 STREET NARC Off Off Auto
6096 Super K Off Off Auto
6128 C.I. 2 Off Off Auto
6160 SRT 1 Off Off Auto
6320 SRT 2 Off Off Auto
6704 InfoCity On Off Auto
6736 SPPur12A On Off Auto
6768 SPPur12B On Off Auto
6800 SPPur12C On Off Auto
6832 SPPur12D On Off Auto
6864 SPPur12E On Off Auto
6896 SPPur12F On Off Auto
6928 SPPur12G On Off Auto
6960 SPPur12H On Off Auto
6992 SPPur12I On Off Auto
7024 SPPur12J On Off Auto
7056 SPPur12K On Off Auto
7088 SPPur12L On Off Auto
7120 SPPur12M On Off Auto
7152 SPPur12N On Off Auto
7184 SPPur12O On Off Auto
