A cannot get my BT Nano to scan Middlesex County NJ. Can anyone help, or maybe post your working ' ini ' file?
This is the ' ini ' file generated by the Nano:A cannot get my BT Nano to scan Middlesex County NJ. Can anyone help, or maybe post your working ' ini ' file?
Middlesex County uses a Harris APCO p25 system, not Motorola. Loading the system again from control channel 769.54375, and running ' learn ' 3 times, does NOT generate any [ IDEN ] section.Looks like your ini file is missing the [IDEN] section.
It will not work without that info.
Run "learn" to gather the info from the system to config correctly.
It may take a few times running the learn to collect all the iden info.
Looks like your Nano worked on the Middlesex system by your post above. Do you have an older saved ini with the iden section? Any idea on what changed?I am using SDRTrunk with 2 RTL-SDR dongles. I am in Old Bridge, and have plenty of signal strength. Middlesex County has 2 sets of frequencies in the 700mhz and 850mhz regions. There is only one active control channel on 769.54375. Reception is fine until there is some traffic on the 850 channels. Then I get garbled or no audio. I can use some advice on setting up this system. I also have a BlueTail Nano, and it DOES handle Middlesex just fine.
Did the Nano work for you as you posted in 2024, or not????I also have a BlueTail Nano, and it DOES handle Middlesex just fine.
Well, it took almost an hour, but I finally learned all data ( and I am in Old Bridge, only 1 mile from two of the sites! ). Should scan mode be 1 or 0? Perhaps you can share your setup.Looks like your Nano worked on the Middlesex system by your post above. Do you have an older saved ini with the iden section? Any idea on what changed?
The Nano DOES work on Harris and Moto. I have 6 systems in my Nano, 3 moto and 3 Harris.
You could try a nano factory reset, clearing the flash memory. Then re-add the p25 known control channel again to gather the iden info. Of course, a good rx signal is needed.
Learn is the only way to collect the all iden info. It may take muliple learn runs to complete the config. Learn is the solution to the missing IDEN section. When learn is run, the Wio display will show the progress of saving the channel info, etc. It only runs for 30 secs. Depending on the system it can take multiple learns. There is no other method to create the iden section.
With only one system/site in your config, no need to enable roam. Roam off, unless you add more systems/site to monitor.Should scan mode be 1 or 0?
Any way to increase the learn time for better results?With only one system/site in your config, no need to enable roam. Roam off, unless you add more systems/site to monitor.
No. It is hard coded. Some systems only take 30 secs to learn, some don't. It really depends on the system as each is different.Any way to increase the learn time for better results?
