BTECH DMR 6x2 Pro Contacts
radiochuck
Traffic Reporter
Phoenix, AZ
Does anyone know how to add the full (but cleaned up) contacts list to this radio? The info for the radio says it supports up to 500K contacts, but the TG/contacts section on both the manufacturer CPS and the one from RT Systems only allows 10K. Am I missing something?
dickie757
Wired
Out of range
From Anytone 878 perspective, TG is different than contact. Contacts are used for private call, TG used for group call.
The way I do it....download user.csv from radioid.net and import it into the tools section of CPS. The CPS then does its work for a minute or two. Then write to radio. On 878, each time you write to radio, cps asks if you want to write contacts and data. I onky write the contacts after a fresh download, as it takes about 5 minutes or so to write them to radio.
radiochuck
Traffic Reporter
Phoenix, AZ
@dickie757 Thanks for the reply. I was a bit confused, it seems.
Using the CPS from BTECH, there's a "Contacts/Talk Groups" section and another called "Digital Contact List" which is what I was really looking for. I imported the big list to that section and all seems normal now. Thank you for the help.
