Baofeng Btech uv-5x3
SSdudley2020
Can you enter a NAC code into the above radio. If so, under what column in Chirp do you enter it. I am listening to a repeater driven sheriffs office channel.
No you can not, that is not a P25 radio, it is not able to listen to P25 frequencies (which are the ones using NAC codes)
Additionally, questions about this radio should be posted in
Budget and Entry Level Transceivers
kny2xb
North Clearwater, FL
You need to buy a P25 capable scanner,
An inexpensive BTech, Baofeng, etc aren't digital capable
And the BTech digital on their site is for DMR, not P25, that isn't compatible either
Plus, CHIRP doesn't support any digital radios at this point, only analog
