BTECH UV-PRO APRS messaging issue, "(NOT AX.25)"
kool_duck
So, I've recently gotten the BTECH UV-PRO (the same thing as the VGC VR-N76), and whenever I try to send APRS messages via the app or the radio itself, Direwolf seems to display the text perfectly fine, but the text "(NOT AX.25)" appears before the message, and hex numbers appear before the actual text itself in the message. aprs.fi using the built in KISS TNC works perfectly fine. I've made sure that in the digital mode settings I have it set to APRS and not BSS.
No software other than Direwolf itself seems to be able to decode whatever the radio is sending out.
Is this intended to happen or have I not configured my radio properly?
KD8DVR
Columbus, Ohio
Why are you using Direwolf? The radio itself *is* a TNC. Direwolf is a software TNC. Just use the bluetooth KISS TNC of the radio and run your APRS software. For that matter, if you are just using APRS, use the radio itself only or KISS TNC it to APRSdroid.
kool_duck
I'm using Direwolf with a different radio that's receiving my UV-PRO's messages.
Coffeemug
Warminster BUCKS Co. PA
I'm really enjoying my new BTECH UV-PRO. Of course, I still have a lot to learn about setting up the radio and linking to my laptop to use APRS messaging. I know I can only program it via android app or by the radio itself. However, I do hope somewhere down the road, that BTECH will come out with a Bluetooth app for Windows PCs to be able to program the radio wirelessly via computer. This function would great for SAR teams and Volunteer for like MS 150 City to Shore. This way if there's quick changes that need to be, can be. Not just for Handhelds, but Mobiles.
k9wkj
where they make the cheese
GitHub - Ylianst/HTCommander: HAM Radio control tool for the UV-Pro, GA-5WB, VR-N76, VR-N7500 radios. Allows for easy control over your radio and APRS messaging.
