ARCXT: Bu-Tel Software
Larry51
Chesapeake, VA
I dusted off my old BCD996XT scanner and tried programming two P25 systems (Langley AFB and NAS Oceana) using the Bu-Tel ARC-XT software. The software did a direct download from the RR website and appeared to work properly. I transferred all the info to the scanner, and it seems to be scanning as it should, but I'm not hearing any traffic.
When I reviewed the settings, I determined that the software only downloaded the control channels for each system. Can anyone tell me if this is the way the BCD996XT works?
For a point of reference, I live about 15 miles and 25 miles from Oceana and Langley, respectively. If I did the programming correctly, distance could be a factor.
CT
For the XT scanners I would download ALL of the frequencies.
Whiskey3JMC
Don't feed the squirrels
Simulcastylvania, TE
lebrunmn
Retired... Get off my lawn!
Hampshire County, WV
lebrunmn
Just realized that I didn't really point you anywhere to get further info about custom bandplans... I would check this guy's excellent website for info about setting up a custom bandplan--I'm checking ARC-XT to see if it can be input there, as well.
To find the info on this page, search: Edit Band Plan (Motorola Custom/P25/VHF/UHF only)
Once you know how to input the Bandplan, you can use the info contained on each system's page.
Not saying that this is a certain solution--just something I'd try if I were in your shoes.
Best of luck.
Butelsoftware
Dayton Hamvention
In the RR import window under trunk options you can select if you want to import all channels or only the control channels
Gommert
www.butelsoftware.com
Larry51
Chesapeake, VA
Thanks for all the responses. Yes, the TGIDs are imported. One follow-up question for Gommert: will the scanner work with just the control channels imported, or do I need all channels?
