Bucks County Trunking Programming
milescoolin
Lansdale, PA 19446
I live near the border of Montgomery County PA and Bucks County PA. I was able to program the trunking frequencies for Montgomery County Police departments but when I try to do the same thing with the Bucks County trunking freqs. I get nothing.
Am I missing something for Bucks County?
I see that the Bucks County trunking freqs. are digital but I do have a digital scanner and receive other digital signals.
Does the order in which you enter the trunking freqs. matter?
I am using a Radio Shack Pro-106 scanner (object oriented based) and one of its features is a capital T display when a trunking system is being monitored while scanning, The T is displayed for the Montgomery County system but not for the Bucks County.
Not sure what is going on here.
Any advice?
scanjunkie
Montgomery County, PA
You need to program Bucks as a UHF system using a base freq and offset. The database here will give you that info. Then refer to your scanner manual on how to program the UHF trunking system. Good luck!!
Skypilot007
Medford, NJ
Boy, someone actually ready and willing to learn how to program a scanner instead of wanting to be spoon fed everything. This was refreshing to read.
