station32
Is all of bucks county TRS digital or is some analog. I want to listen to fire only and i was wondering if it was digital. Any information will be appreciated.
This thread seems to be a good place to ask my question......Has anyone upgraded their BCD396T to Firmware v3.01 and still getting pops, clicks and dropped TRS P25 digital audio in Bucks Co.? If so, can anyone give me some tweaking instructions to lessen these annoyances? I've tried both auto and manual mode.
Does anyone have a GRE PSR-500 handheld that listens to Bucks P25 digital. How does the digital audio sound on the GRE radios?
While you are waiting for someone to hold your hand on this, suggest you read this Pro-96 Cheat Sheet No, your scanner does not come with fire grounds, but you can easily enter them if you look at the Bucks County Countywide Fire (Conventional) Section. The fire grounds listed here are not digital. You can enter all of the frequencies in this table, and your local FD UHF, using the Programming - Storing known non trunked frequencies section of the Cheat sheet. After you have done that, you should look at the Bucks County Digital System You will notice that there are 4 systems by area. You may not be able to hear all the areas, so look at the frequencies (see note) for the one closest to you. You can enter them using the Storing known trunked frequencies instructions. It should be fairly straight forward if you follow the instructions.i just got pro-96 and new to digital, can i still enter in fire dispatch? or is als already on digital? i live in bucks county? also can i enter in my local fd UHF? any help is greatly appreciated. also does the pro-96 come with fireground 1 and 2 programmed? are they digital?
Entering the DEC value for each talkgroup is explained in Storing known Talkgroup ID’s. If you wanted to take the easy way out of entering the talkgroups, you can run your scanner in the "open" scan mode, and it will get all the talkgroups without you having to enter them. "To change from Open Mode to Closed Mode (or the reverse).
Press FUNC + 5 (Bank Open or Bank Closed will display)."
Note: your scanner has Control Channel Only trunking so, per the article, you really only have to enter the RED and Blue frequencies. (don't try to enter the "c" or "a" after the frequency)
DisclaimerI am not from your area, so I am only showing where to find info. Someone from your area will no doubt correct me if the database is not up-to-date.
