Buffalo Grove Fire Department
Chief_601
Muncie, Indiana
I am trying to monitor the Buffalo Grove FD in Lake County. I understand that they are on a trunked system but I'm not sure of the frequencies or talkgroup ID's. I have the Lake County EDACS system programmed in but still haven't had any luck. Suggestions?
Thanks,
David
N9JIG
Sheriff
Moderator
Far NW Valley
Thanks,
David
As Jim already mentioned, they are on the Northwest Central Dispatch digital trunked system, not the county EDACS system. In addition to the resource here at RR that he posted you can find information in the CARMA Profile at www carmachicago.com/profiles
mrd584
did this ever work for you Chief_601 , i could use some help ?
