Building a test jig
ZS6HZ
Sønderborg, Denmark
Hi all,
I want to build a test jig that I can use to test the acc port on DR3000's and the DM series radios. My idea is to put a 26 core cable onto an accessory plug, and run it to some form of terminal strip that can then be used to interface with peripheral equipment quickly and easily.
Ideally I'd like "push" terminals on the peripheral side so I can easily swap wires around, and if possible, a switch in line with each of the 26 terminals so I can physically switch a line on or off as well as do it via the CPS.
Does anyone know of a part number of a terminal strip/s that will do this? Preferably RS Components because they have an outlet here in Johannesburg.
I hope I explained what I'm looking for clearly. ;)
Also, while I'm thinking about it, it would be really nifty to be able to visually see the state of the specific pin (high, low). Does anyone know of a simple device that will isolate the pin from an LED without loading the pin?
'73
Marc
