Building inverted V for 10 M - What RG8 is best
Chip4Par
Florida
I am building an inverted V for my 10 meter mobile and was wondering if the Davis Bury cable or 9913 would be the best shoice for the feed line?
I am getting back into HAM after about 20 years QRT and am re-learning a LOT!
73's
Hank
LtDoc
Oklahoma
Hank,
It depends on the length of the feed line. For less that maybe 100 feet, almost any coax would work fine. I think something like RG-58 would work okay for shorter lengths, maybe 50 feet or less. There's no practical need or benefit using '9913' or LMR-400 and such at HF. Losses amounting to less than a dB or two are meaningless at HF unless there are a bunch of them. That's not the case with VHF/UHF, but it is for HF. If you just feel like you should use a 'better' coax, it's your wallet, knock yourself out!
- 'Doc
Chip4Par
Florida
Thanks for all the suggestions. I found some RG8x pretty cheap and I am definately going to keep it under 50'. As I start getting back into HAM I'll probably get a better rig and antenna system. But for now I just hope I can get my antenna tuned!
73s
Hank - KA4KBD
LtDoc
Oklahoma
K9RW,
Okay, but how about that 75 ohm impedance? The input impedance of most inverted 'V's will be much closer to 50 ohm than 75 ohms.
- 'Doc
Chip4Par
Florida
Doc;
The web site for Universal Radio has the RG8x listed at 50 ohm! Are they messing with me or am I missing something?
Hank
LtDoc
Oklahoma
Chip4Par,
No, you wren't mistaken about RG-8X being 50 ohms impedance. I should have made it clear that I was talking about RG-6 coax which was suggested by K9WG.
While that 75 ohm coax may provide a nice match between a 'flat top' 1/2 wave dipole and the feed line, you'd still have a 50/75 ohm mismatch at the transmitter. If you 'droop' the legs of that dipole, you lowered that 75 ohm input impedance to something closer to 50 ohms. So, why not take advantage of that and use 50 ohm coax? The -only- redeeming quality about that RG-6 is that it's cheap. Try soldering to it...
- 'Doc
Chip4Par
Florida
OK Doc, thanks.
I am going with the RG8x because I MAY get a bigger rig and use the same line on a different antenna. I'll see how this 10M set up plays out.
