JohnnyFingers
Can I trust the SWR meter that is built in to my mobile radio?
What mobile radio are you talking about? We can all help you find a good SWR meter. Invest in a good one that will last you a lifetime. Also, let us know what frequencies you might be needing to check. That will govern the type of SWR meter that you should get.Can I trust the SWR meter that is built in to my mobile radio?
Haven’t owned a CB yet where “the inaccurate meter “ caused me to lose RX/TX.
An outboard meter is enough even at the $30 level. Anything below 2.1:1 is adequate. For those running amps, etc, a better device is needed.
1.8:1 I’d still try to get SWR lower.
At 1.4:1, I wouldn’t.
1.5:1 marks the line.
@Jehirsh2386, how long is the RG58A/U jumper that was used between the President McKinley and the SWR Meter?
I am using a 3 ft jumper and the adjustments were made to the antenna. There isn’t any special equipment in line with the setup and the radio is stock. Also for set up info sakes, I have a 4ft fiberglass tunable tip antenna with 50ft of the rg8x with extra figure 8 bound down to radio and stock mic. The power supply is about 2ft away and the coax and power do not cross eachother.When you adjusted the swr was that a physical adjustment on the antenna or adjustment with an antenna tuner built into the swr meter?
