Burlington county fire
#1
Does anyone know what the TG ID is for either Burlington County, or Mount Laurel fire dispatch? Or does it only dispatch on 154.2200 Mhz?
Brick Twp., New Jersey
#2
154.220 is used for dispatching. I'm not an expert on this topic, but I do know that on this particular type of trunk system it is not possible to dispatch via a talk group, as it will not set off the firemen's pagers. I don't know if this applies to all trunk systems because I have seen talk groups labeled "Dispatch" on other systems but I don't know how it works. In the case of Burlington County, however, it's all done via 154.220.
#3
Thanks for the info! :p
