I have just acquired a Dentron 160-10L amp with 4 576B Cetron tubes that appear to be in good shape
The unit has been sitting idle for at least a year or so without transmitting,
Is there a recommended procedure to "break it in" before use?
Once it is up and running, how hard can it be run in the first few hours to ensure that the tubes are hot enough for the getter to do its job - full power , half power, etc? I will use an oil filled dummy load, so extended use should not be a problem.
