Burst Data
n1chu
Farmington, Connecticut
I am bothered by those data bursts at the beginning or end of transmissions. I realize the burst data are necessary and part of each transmission but they become annoying. Is there anyway of muting them?
nessnet
Eastside of Lake WA
Is your modulation set at auto, or...?
gary123
it sounds like he is hearing the MDC ID burst. There is no setting to automute them.
n1chu
Hopefully they aren't encrypted, because the FCC doesn't allow scanners to even stop on anything encrypted.
No, the service I am listing to has no encryption capabilities. Although you could reason the digital data bursts are decoded and displayed on a flat screen monitor. These data bursts contain simple info, such as the radio ID. It tells dispatch what radio is transmitting on every transmission. (I imagine it has the capability to transmit GPS info in the data burst in the event the emergency button is pressed. But I suspect the system I’m listening to these data burst contain GPS location info on every transmission as I’ve heard dispatch state which unit was closest to where they were to be sent. I’m listening to an unencrypted service.
GTR8000
NY/NJ Database Guy
BEE00
Are you referring to MDC-1200? Is this conventional analog you're talking about? If yes and yes, the answer is nope, sorry. Get a real radio that is capable of DOS muting if it bothers you that much. 🤷‍♂️
n1chu
Yes, I am aware but I already know what is being broadcast. I’d just like to eliminate them and as I stated, I pretty much knew there was nothing I could do about it… that I was just making sure I hadn’t missed anything.
