Butel Software Help
KC8FAS
Moran, Michigan
Is there a way to edit profile/display using the Butel software for the sds 200 . I see you can do it with the Sentinel software.
Saint Charles
Is there a way to send a command to the scanner to switch between serial and mass storage? when doing a lot of experimenting I would think constantly removing the cable would not be good for the Jack. I have the 536pro and both x36 scanners.
