Cabin Pressure prblems Right Now!
N1SQB
Somewhere On Earth
Southwest 281 reporting cabin pressure problems requesting rapid decend. Boston AirCenter Freq 128.1! Went from@24K to 12K in less than 4 minutes!
You could hear the beep beep from the alarms when the pilot talks!
Manny
Helo-Pilot
Southwest is already in hot water right now for not complying with mandatory airframe inspections for fatigue cracking. I hope, for all those involved, that this is not related.
N1SQB
Somewhere On Earth
I hope not!
The pilot went down to 10k feet. They fixed whatever problem it was for the moment because I heard them ask to go up to 12K to test the "fix" then they requested 15K and higher so I believe all was well after that. I read that same article. Unbelievable what they are getting away with. Downright criminal.
Manny
