First step is to call your cable TV company and report it to them.
With all due respect, the first step is to make sure YOUR OWN house is in order.
Be certain all F-Connectors from the splitter or ground block to each and every
TV, Cable modem and Cable Converter are snug.
Be certain all the coax cables within your home are 100% cable company supplied
or meet their spec for shielding.
Very common causes of leakage is poorly shielded coax jumpers
that come with consumer products, non-cable company supplied splitters,
and poorly crimped or twist-on F-Connectors.
Another common cause is just plain cheaply made TV tuner packs within TV's.
Cheap Chinese junk to be blunt.
If you live on a postage stamp lot in the city or an apartment,
it could also be from similar issues with a neighbor.
You can easily find the source by using a 2m handheld as a cable leakage sniffer.
Good luck!
Ex-cable TV employee here (and a ham).
About 90% of leakage problems are in the residence.
Granted, there is that 10% leakage found in the company plant too...
