offfor4 said:Can I use cable tv wire for an antenna? I would like to use the already wired cable in my house to get an outside antenna source.
N_Jay said:The wire YES, (it is probably RG-6 or Equal.)
The wire as it is installed, probably NOT, unless you know it is a strait run and not connected to anything else.
offfor4 said:is this going to be a good antenna?
ve3nsv said:Just cut back 19" of the insulation leaving the center conductor exposed at the end in the attic and you will have a perfect VHF 1/4 and 3/4 on UHF. Be sure to leave the 19" verticle and in the highest spot in the attic for maximum performance.
fuzzymoto said:I just ran RG-6 (DishTV coax) to my attic. As it stands it does NOT work as an antenna. I'm playing with connections and I am new to this but I believe the coax is shielded and will not act as an antenna. I think you can make one end of it into an antenna but as it stands I don't think plain sheilded cable will do anything.
Or peel the shield back over the cable, so you have outer shield, outer insulation, inner shield, inner insulation, center conductor. Cut off about 22" of outer (black) insulation, then trim the shield to 18" after you're done peeling it back over the cable.N_Jay said:You can leave the insulation on, just take the shield off.
Of course what you really want to do is fold the shield wires back so they hang down, like a very limp ground plane.
kc4jgc said:It can work. Bear in mind that tv coax is 75 ohms. Scanners and antennas are generally 50 ohms. What you'll need is something on both ends to compensate for the impedence mismatch between antenna and cable and then between cable and scanner.
My advice would be to buy a new 50 ohm coax, then have that fished inside the walls to an outlet placed near your scanner.
