caldwell FD FG channels
#1
recently found these channels at a Caldwell FD incident they appear to be fireground freqs
154.0900
155.3250 C186.2
SCANdal
Silent Key
Hudson Valley, NY
#3
154.0900
155.3250 C186.2
313,
The actual frequency is 154.0925, used with tone 306, under the license WPKT809.
SCANdal
Brick Twp., New Jersey
#4
The reason you saw 154.090 is because of the setting of the step size. If you set the step size for that channel at 7.5 and program the frequency, it will show as 154.0925.
