Call me slow
M105
What version of DSD+ are you running? The 2.8 Fastlane does a lot more with P25. You could also try using -f1 -v3
kma371
The control channel is continuous data. You won't see anything until you go to a non control channel. Try a frequency on the system that isn't a control channel.
Edit. Got half way through and thought I found your issue but it looks like you tried that.
It sounds like you want to view activity across the entire system. Dsd isnt a good program for that. Pro96com is what you want but I don't know of its compatible with winradios.
slicerwizard
Toronto, Ontario
Can someone help me figure this out?
You're not using the latest DSD+ version, which decodes P25 control channels. You're not even using the latest public release...
DSD+ 2.8 decodes all of the P25 control channel activity - affiliations, patches, FDMA/TDMA individual and group calls, neighbour sites, bandplans, rejections, busies, secondary control channel frequencies, ...
I'm using the rtl-sdr.com dongles and performance on the half dozen simulcast systems here is fine. Still missing Phase II voice decoding though.
IMPRES2
I did try what I could before asking as I hate looking Amerture at times. Yes, I do want to see the entire system data. What would it take to see that through Pr96com? (Hardware, software, whole nine yards)
kma371
Sorry, I guess I should have said I preferred pro96com over DSD, not that it wasn't a good program for it. I use both quite frequently though.
kma371
Like slicer said, you can download the most current version of DSD to see what you want, or you can go to pro96com page for more info of that software.
Both work well.
rylvir
CA
If you want to see everything going on during the voice channel decoding while running DSD+ (as M105 mentioned earlier) you can do this by turning the verbosity up by adding -v4 switch to the command line. If you are looking to decode the control channel messages for system wide information you should look into Unitrunker. Pro96Com is great and I have used it but it requires a compatible scanner, whereas Unitrunker only requires a cheap SDR dongle.
Unitrunker
This guide is a bit old but its still helpful, if you are not intending on following voice just check out the first section "Setting up the Signal (Control Channel) Receiver"
RTL-SDR Tutorial: Following Trunked Radio with Unitrunker - rtl-sdr.com
I think there are better options out there when it comes to following a P25 system and decoding audio with an SDR dongle, namely SDRTrunk and OP25 but I still use Unitrunker for control channel decoding, and system analysis.
IMPRES2
Updates: I did NOT have the latest software and upon getting that (through fast lane) I was able to quickly see everything I wanted no problem. The WinRadio G305e works flawlessly with Unitrunker and DSD+
Thank you to all!
(Can we close thread?)
