Call tone for MCS2000
fs6591
Hi, does anyone know how I can add a 1750 Hz (or another frequency) call tone on a MCS2000? It is A VHF radio, model M01KHM9PW5BN.
Thanks in advance
FN
jruta
Nj
Does that radio have “single tone” ability? (I’m not sure if that’s even used anymore) but that would be a way to do that.
fs6591
I don't know. In which menu should I look to find out if I have this ability?
fs6591
Now I understand what you mean. In the menu for the conventional personalities in the codeplug there is a tab "Signaling", and if I choose the option "MDC" in this tab, the menu in the tab "RAC" in the same personality can be accessed. However, only the option "MDC" can be chosen in this menu, no singletone. Do you know if I can get the MDC to make a singletone in some way?
jruta
Nj
I don’t believe so. I believe “single tone” is a different signaling option that might not be available in that radio. MDC will give you that data burst, it’s different than single-tone. I recall my older portable radios (Jedi series) had that.
I used to “ping” a short, 1000hz tone prior to transmissions to open repeaters.
Others may know better than me. Sorry
fs6591
Thanks, I have actually built an external audio oscillator that I hold in front of the microphone - not the most professional solution, but it works!
Maybe you can help me with another annoying problem: when I put a PL tone (CTCSS) on the receiver, the MCS2000 also receives emissions without CTCSS (from my signal generator, for example). Every personality has 3 options in the submenu "Unmute/Mute Type" of the menu "RX options": "Standard", "And Unmute, Std Mute" og "And Unmute, Or Mute", but none of them work. In transmission, the CTCSS codes are transmitted normally. Any idea what I can do?
Thanks in advance
