Calling all Uniden MR8100 owners!
Squelchtone
Wilbraham MA
#1
Dear Members and Uniden MR8100 owners,
I am working on a project to document the history of the Uniden MR8100 scanner. Part of my research has to do with Date Codes and Serial numbers. I am trying to get a list of as many as possible.
If you can help and don't mind posting your Date Code and Serial number on the forum, or emailing me directly at Sequelchtone at gmail dot com, I would greatly appreciate it. Please also state if your radio's antenna connector is on the side, or comes out of the bottom, and if your radio has the On/Off power switch on the side or just the wires coming out of the bottom.
I'll start the fun:
My 2 MR8100's are
OGIO 05001020 (all wires out of bottom)
OGIO 05001361 (all wires out of bottom)
I have also seen
OFIO 05000380 (all wires out of bottom)
Thanks for your help!
Squelchtone
Uniden MR8100 Yahoo! Groups
[owner/moderator]
K
kb0nly
Guest
#4
I used to have one too... Kept it for about a year, then a distant agency came on the same frequency as my local fire channel and without the tone squelch the 8100 was useless for scanning here. And now we are moving from VHF even.
Good scanner though, mine had wires out the bottom, a pigtail with a BNC female for the antenna out of the bottom as well. Didnt know they varied any in that regards. The only ones i have seen had all the wiring out the bottom and the power switch was part of the volume control. Although you could leave that turned on and turn it on and off via the ignition sense wire.
I still have the software and such for it on a disc, if anyone ever needed it. Pretty sure its widely available online by now also.
Squelchtone
Wilbraham MA
#5
My email address in the original post is incorrect.. it is SQUELCHTONE AT GMAIL, not sEquelchtone as was written above.. sorry about any confusion.
Squelchtone
yfdgricker
Youngstown, Ohio
#6
I had one that I sold a while back and I just picked up another one because I missed it (and it will look great in my 1981 fire truck in the summer).
The date of MFG on the one I have now is OJHI
The serial number is 95002008
The back plate is different from the one on yours Squelchtone.
All of my wires come out of one hole in the bottom with flex tube around them. There is the pig tail with BNC for an antenna, red and black for power, green for ignition and white/gray for the speaker. My power button is in with the volume knob.
The old one I had, had the BNC antenna connector drilled out from the side of the unit.
The one I have now does have an earphone connection on the left side of the unit and on the right side, it has a cover molded into the case where a power switch could be put in if you cut out the plastic. Directly under that is another circular plastic area which might have been for the BNC antenna if it were cut out.
Squelchtone
Wilbraham MA
#7
Thank you for the very detailed reply, exactly what I'm looking for. I would love to see a photo of the back plate on your radio, any chance of posting it here?
Thanks!
Squelchtone
Chesapeake, VA
#8
I still have mine, it also has the pigtail out of the bottom with the power/volume knob.
Date - OKHI
Serial - 95004344
I wish there was a way to make it trunk. Oh well, still a great scanner for it's time!
Squelchtone
Wilbraham MA
#11
Thank you to all who have participated so far both here and on my MR8100 Yahoo forum group.
Still looking for more folks to step up and help us fill in some more serial numbers and any photos you wish to share.
Keep em comin guys, thanks!
Squelchtone
Squelchtone
Wilbraham MA
#13
I had one and sold it. Worst move I ever made. I'd love to get another.
Oh man, you think that's bad? I had 2 MR8100's which were 1 serial number off.. basically I had number 05001020 and 05001021 both from a CHP ebay auction from that one guy who used to sell a bump of them. I sold number 05001021 when I needed some money and I've been kicking myself ever since. That was about 10 years ago.
Squelchtone
jack103
Tewksbury MA
#17
My 8100 has a date code of OIHI and a serial # 95001927
All wires out of the bottom with phone plug on the left side
Dont know the age of this scanner but it is mint.
Squelchtone
Wilbraham MA
#18
Made in November 1989. ;-)
Seems from the serials people have submitted so far, the 1989 MR8100's serial numbers start with 9500 and all the 1990 radios start with 0500. Interesting that they would make this change mid production.
Squelchtone
Attleboro, MA
#19
Squelchtone
Not if the first number of the date code is the last number of the year of manufacture, a la Motorola battery date codes.
