Camden City Fire Dept
fliweele
Philadelphia
Does anyone know if the city of Camden's Fire Dept. uses trunking (like city police) or are they still using conventional?
Audiodave1
Chadds Ford, PA
Hello,
They are still conventional at this time.
I did just see an FCC filing for Camden City so that might be changing.
YF WPYD478
Camden, City of
1 - 6th and Market Streets Camden (CAMDEN) NJ
866.6125 370' FB2 30e
866.7375 370' FB2 30e
867.7875 370' FB2 30e
868.1875 370' FB2 30e
868.7 370' FB2 30e
2 - Locust and Kaighns Ave. Camden (CAMDEN) NJ
866.6125 170' FB2 60e
866.7375 170' FB2 60e
867.7875 170' FB2 60e
868.1875 170' FB2 60e
868.7 170' FB2 60e
Dave
murphdog
They are still on VHF. Those fillings probably have to do with them adding a frequency because they will be combining their system with the new DRPA system.
fliweele
Philadelphia
Confused
:confused:
1.If Camden's Fire dept is on VHF now, I don't see the frequencies in the previous postings.
2. Audiowave: It looks like you listed two zones. What in the world are those numbers? 370' and FB230e? Are they talkgroup I.D.'s?
Please explain.
Audiodave1
Chadds Ford, PA
Hello,
Those #'s are the tech details of the transmitters.
It is a 2 site system. (like many city radio systems)
Antenna height expressed in feet (370')
FB2 means it's a repeater
30e means it's output power is 30w including antenna gain.
It's FCC license speak.
Dave
Camden, NJ
Audiodave1 said:
Hello,
YF WPYD478
Camden, City of
868.7 370' FB2 30e
868.7 170' FB2 60e
Dave
has any one known if these channel has been changed and what is the freq. for these channels are they vhf I was wondering because I dont really know how to deal with this pro 94 it seems like junk so far.
Camden, NJ
scanner man I just recieved the codes and I was picking up police bands on those same channels the others I used for camden wasnt working I cant figure this out but thanks. I like in a high rise apt would that matter and I have the rubber buck ant. should I get one thats strong , I use my scanner when I am out in the store so the ant. has to be mobil and also that soft ware that comes with the 96 and 92 pro the scan net is there a way i can use those freq. ?
delran nj
are you programming them in the order i posted? are you in trunk mode ericisson? check and let me know,are you searching talk groups?if not you have to proggram talk groups in to just scan them i'll get talk groups and post them.
joesass
nj
camden pd\
who is useing the camden old trunking freqencys
and there about 20 talk groupss or more
