Can a cell tower block 800/900 signals?
paulsfd
I had a BCT780 that always picked up the local 800 Trunked system with no problems. About a year ago I noticed it wasn't picking it up anymore (Figured the scanner was dying from being on 24/7 over 8 years). Well, I just got a BCT15 when the 780 finally did die, but it too will not p/u anythng in the 800/900 range (not even interference). After scratching my head, I think the nearby cell tower (about 1/4 mile) maybe to blame. Any thoughts?
Stick0413
Hopewell, VA
It isn't going to help that is for sure and it could very well be the problem. You might want to try filters. I am not all that vested in them but others here are and can point you in the right direction.
delta_p
It isn't causing me any problems with 800 Mhz. I have a yagi aimed across two of them to get to my tower. The reception is always clear.
PP
C
comsec1
Guest
sure it can
the noise floor around the cell phone tower is much higher then the signals that you want to receive effectivly jamming your receiver. this is part of the reason for rebanding.
Garymaxon1234
Yes they can, I have to be careful with my BC396 at my daughter's house. The tower is right across the river. It causes noise and blanks out transmissions. The signal from the SAFE-T tower is strong enough I either lay the scanner on it's side and point the antenna away from the PCS tower or sometimes take the antenna off the scanner.
GT
reconrider8
Eastern, NC
well how would you stop it from doing that cause i live like 2 miles from one and i pick up a lot of blank channels to sounds like it has some static or something in it
zz0468
Banned
An unequivical YES! They can... cell towers and the interference they cause, particularly Nextel cell towers, are the root cause of the whole 800 MHz rebanding fiasco.
austin51648
Auburn, NE
800 mhz
Most scanners will not pick up 800 mhz frequencies.
n2mdk
Ames, IA
Most scanners today certainly will pick up 800MHz many of the public safety trunked systems are on 800MHz.
SLWilson
Ohio
You're right...
If 800MZ is what you are mostly interested in, you probably will need to get a good Yagi antenna and zero it in on your areas law enforcement tower. Hopefully it WON'T be across the area where the cell site is. But, you are correct in your thinking that the cell cite is killing your RX.
Steve/KB8FAR :mad:
n1das
Nashua, NH
???? All of the scanners listed in my sig (and many many others) will recieve 800 mhz freqs.
Technically, he IS correct. Most scanners will not pick up 800 mHz frequencies. In fact, none will that I'm aware of.
However most scanners will pick up 800 MHz frequencies.
800 mHz = 800 milli-Hertz = 0.800 Hz
800 MHz = 800 Mega-Hertz = 800,000,000 Hz
Root cause is the close proximity to the cell site is overloading the front end of the scanner, effectively "de-sensing" it and making it deaf enough to have trouble hearing the desired public safety stuff. If the scanner has an attenuator, try switching that on.
Good luck.
Chicago
Good luck.
Then what the heck is a "hz"? I know the "Hz" unit but am unfamiliar with these "hz" units. ;)
kc4jgc
Virginia Beach, VA
wannabescannist said:
Understood, but what is this "hz" unit. if m != M then hz != Hz............
Hertz= cycles per second. On older radios, you might see "Mcs" or Megacycles. The terminology "cycles" was changed to "hertz" to honor Heinrich Hertz, one of the fathers of radio.
