Can Anyone Identify a Moto connector? Or perhaps suggest one?
Radiocar
Salty Coxswain
Los Angeles County, California
So before posting I've done my prerequisite and courteous 4 or 5 hours research before coming before the well versed and knowledgeable forum that is Rad-Ref. Sadly I couldn't find any information on the dilemma that I came across earlier today.
So while running the streets of northeast Los Angeles county I've found a guy trying to get rid of fifty or so lightly used moto microphones (maybe dumped by a federal or parking service agency, mostly HMN1090s. XTL and I think PM connectors, some vintage ones as well') for 10 bucks each! (Liquidators... am I right?) I was like... "I got you fam, run me 3 of those h*es." I had the idea of using them as an upgraded replacement for the 4 pin Uniden mic that came with my Pro 510xl.
My question is, does anybody know of any 4 pin to 10 pin adjunct or know of any schematic that is available for wiring a Motorola OEM audio radio cable to a 4 pin connector.
I have a general understanding of electrical literacy and I am familiar with Uniden's vintage method of pinning, ie, (check at my latin homie) 4 pin mic input, mic gnd for the female jack. And a little on PTT closure like the (PTT) pin and (GND) pin. However, I am nowhere near proficient enough to dive into something like this blindly.
I have found a few Moto Car Mics that is wired up to a 4-pin connector on eBay but the sellers are fairly tight-lipped so that's that.
Any advice, tips, thoughts, observations, and opinions are greatly appreciated
TL;DR: 4 pin to 10 pin Motorola Microphone (HMN1090) wiring method or adapter?
EDIT: Also, if anyone knows, what is the 10 pin connector called on the hmn1090... Mechanical Name or part number?
Often the CB's use dynamic microphone elements. The Motorolas use a condenser mic. They won't be compatible without a huge amount of work. That'll include supplying bias power to the Motorola mic from the CB, matching impedance, and sorting out the push to talk. That'll mean you need more than 4 pins on the mic connector.
While it won't improve the audio, one approach would be to gut the Motorola microphone and disassemble the Uniden mic. Install the Uniden innards inside the Motorola housing.
Back a long time ago when I had a CB with a microphone that had horrible ergonomics like yours, I did the same thing.
As for the 10 pin connector on those mic's, I'm sure Motorola has a part number for it, but more than likely they just sell you the whole cable. Looking at the HMN1090's I have, it's molded to the cable. They are, as far as I know, specific to Motorola.
Radiocar
Salty Coxswain
I do like the option of gutting the mics. My intentions are purely aesthetics. I love the look and feel of Motorola's white mobile mics, its something that I have been using for years and the durability of it is a bonus.
I think my plans will involve picking up a thicker coil and splicing it to the leads and installing a rubber grommet to hold everything in place. I doubt the board will be permeable so I do expect circuit and solder work but I do have faith in the project. Fortunately, the PTTs are in a similar place so I am sure adding and subtracting silicone will help me in matching everything up.
Hopefully, no one will be wise on a Uniden MK393 inside the housing of an HMN1090. Thanks for your input.
I don't own any radios that requires10-pin so the mics will not be missed.
