Can Blackice stream from a USB SDR?
jshg46
Can anyone answer this. I am setting up a new machine. I have debian Jessie and would like to use darkice to sent to my icecast server. Can this be done? If so, how?
shores
i think you can, but not sure how you have the audio setup on your pc.
you might have to use the speaker/line out on the sound card for your output, and then your mic/line in on the same sound card input to darkice/shoutcast.
i used dark ice with a bct8 and other scanners without issue using line in.
Not sure if it can be done all digitally, as typically sound output from software only lets you choose outputs not inputs.
a simple 1/8 to 1/8" line cord between the two should let you output from unitrunker/sdr and input into darkice and away you go
jshg46
In linux, Vsound seems a lot like asound. Shores, I think the deal im using a sdr usb dongle. If I had an actual radio I think it would be easy to setup. I just need to know how to hook It all in. I can use ezstream for my feed but, would rather use a program that can do more than one stream on the same input.
