Can I Access Just One Brandmeister Networked DMR Repeater On Local 9 Via A Hotspot?
JASII
Memory Capacity
As posted above, there are some DMR repeaters near me that are using Brandmeisier system.
Using a DMR radio, you can access just the local repeater only, using TGID 9 (Local 9), and the correct RF frequencies Color Code and Time Slot and bring up just that one, specific repeater.
Is it possible to access that same repeater, using a hotspot, and bring that one up only?
JASII
Memory Capacity
Thank you.
popnokick
Northeast PA
Unless it's been restricted by the repeater sysop, if you use the DMR ID of the repeater as a talkgroup in your hotspot (codeplug of your radio) you can access the repeater... and only that repeater... via the hotspot (Internet) from anywhere on the Brandmeister network.
JASII
Memory Capacity
That is great to know.
Thank you very much!
