DylanMadigan
I see the option in CPS but it is grayed out. I know it's possible for these to turn on with vehicle power, as our FD uses them, but mine seem to not let me do that. I got mine used on ebay through some police department.
Yes, but since most people wire the radio to the battery, it would always have power. That's what the IGNITION SENSE wire is for. But yes, if you could wire the 12+ feed to the radio to a wire that was hot only when the engine is running, that would work too, but might not be capable of supplying the current the radio needs during transmit.I was under the impression I could just set the radio where when it receives power, turn on, until the power is removed and it cant be on.
Where would I find this accessory kit?
And I have a 150amp circuit that only powers on with the key in battery or running, or with the override switch, so I have something to connect to.
Set the CPS Ignition Sense to On/Off & Igniton. That way you can manually turn it on or off plus let it go on/off with ignition/accessory. On/Off in the CDM's is by pushing the volume knob, not turning it.
Find the user guide online, download it, and study it. Details like the on/off button are all in there.
The "Ignition sense kit" is nothing more than a wire, a fuse, and a connector that fits the accessory socket on the back of the radio. I believe it is pin 25 but may be different with your particular radio. The "kit" connects to a +12 volt ignition switched source. It can be connected to any +12 volt source if you don't want the radio to turn off/on with the ignition. (This also needs to be programmed in the radio to work correctly).
BB
you can also jump pin #4 and #10 on the accessory plug and wire the MAIN HOT wire to IGN power on\off
I've been studying and researching the CDM's for over five years since that is the primary radio for this whole county. This is the absolute first I have heard of the 10/4 jumper solution for permanent ignition sense. The 7/4 solution has been commonly discussed over the years, and there have been numerous discussions of ignition sense problems with no mention of 10/4 as a solution.No, pin 10 tied to 4 will accomplish what the OP is looking for. We have several in control station configuration using such a jumper and it means the radios will always power back up without the user having to think about it (like when the power goes out).
I don't know how "legit" it is as far as Motorola is concerned but pin 4 always has 12 V on it and if you're not using using it, it works tied to 10. The senior techs at work taught me this trick.I've been studying and researching the CDM's for over five years since that is the primary radio for this whole county. This is the absolute first I have heard of the 10/4 jumper solution for permanent ignition sense. The 7/4 solution has been commonly discussed over the years, and there have been numerous discussions of ignition sense problems with no mention of 10/4 as a solution.
How should Pin #4 be programmed for this fix? According to the help file for the CPS, low is the only active level that the radio acknowledges for Pin #4.
