One thing that makes the GRE user interface so much more friendly is the name of the list is displayed when you toggle it on/off. It would be nice if when you use Quick Keys the name just affected was briefly displayed. I see there's a way to list all Favorites, or all Systems under a FL and toggle there. Is there a way to do this with Departments?
While I like the way Uniden manages multiple Sites of a Trunked System; they do not provide an eloquent way to manage conventional & trunked together. In other brands I can assign all Talkgroups & Conventional channels in a county to the same list.
With the SDS you must define a System as either being a Trunked System or Conventional System, which by doing so, means they can't be combined. To make matters worse, because conventional frequencies must be within a Department under a Conventional System, there appears to be no similar on-screen method to select Departments (like are provided for FL & Systems).
