Can I program a freq to RX only and not TX?
jreinhar
Florida
Hi there,
I recently purchased a Vertex VX-451 and I am using CE115 v.1.10 software to program it. I am wanting to put in my local NOAA freq but I want to prohibit TX for obvious reasons. Is there an option to do this? I tried leaving the TX freq. blank and that didn't work, I tried entering 000.000 etc but get the out of freq. range.
Any help or suggestions is much appreciated!
-John
DeadMike
California
Hi there,
-John
Not familiar with your software but the program I use I would: Duplex = Off
Maybe you can set it to that?
jreinhar
Florida
No option for that (at least that I know of), I know Chirp uses that but my radio isn't supported in Chirp. :-(
msrettinger
Oelwein, Iowa
I did that with my VX-4600 which uses the CE-115 software. I don't remember exactly what I did, but when I open the program it says ---.----- in the transmit column.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Hi there,
-John
At first I figured if you just deleted the transmit frequency, it would be a receive only channel, like my Kenwoods... Not so with CE-115, even if you highlight and delete the transmit frequency, the software pulse with an 'out of frequency range' error... Very odd.
Even after searching the help files, the only references I see to either receive only or TX inhibit are for LTR or 5-Tone... All I can suggest is to set the transmit frequency to one of the MURS channels, with the proper deviation, and power level, or if you are a ham, set it to a simplex frequency, like 146.505 or 146.500 and set the power for only low.
Really odd... Another reason why I like my Kenwoods!
Sent from my iPad using Tapatalk
jreinhar
Florida
Ok a friend just told me to highlight the RX freq and then hit Space and that worked it put the dashes in!!! Yay!
Thanks for the suggestions and the help, hopefully this will help someone else too!
kayn1n32008
Sector 001
Wish they would document how to make an RX only channel...
jreinhar
Florida
Their programming software is kind of clunky, but luckily I do not have a lot to input! I did just program it and it will not TX on my NOAA channel now so at least that worked out! :)
kayn1n32008
Sector 001
Glad it worked out, learned something new... Still like how Kenwood allows you to simply delete the TX frequency to create a RX only channel better.
jreinhar
Florida
I hear ya, I own a few TK260G's and a TK272G and I like the simplicity of the KPG-56D software!
kayn1n32008
Sector 001
I own TK-2&380, TK-760, and a NX-700... Even the NX-700 is a breeze to program for analogue/conventional. I really like my Kenwoods, especially the 12 character dot-matrix display... Although my company issued handhelds are vertex, I would rather have Kenwood, vertex is still 'growing up' and stuck on segment displays with limited characters.
W7FDX
NC Pennsylvania
I have a Vertex VXD 720 and love it but I will agree I do love my kenwoods.
jaspence
Michigan
You can put a frequency in the transmit box that is either out of the radio's transmit range or at least out of the NOAA range. Not as good a choice, but better than interfering with the broadcast.
sibbley
Nazareth, Pennsylvania
Thanks for this fix. I always set the TX to an oddball then locked the PTT.
Project25_MASTR
TX-COMU
Texas
Looks like you found a solution. I was going to suggest typing "blank" in for the tx frequency.
RodStrong
West
Vertex software is a pain. I'd buy a lot more of their radios if it was more user friendly. Too bad.
jreinhar
Florida
I agree! I went from a version 1.08 to 1.10 hope it was easier but it's not! :-(
sibbley
This was the first and last Vertex I'll buy. I don't like the software at all. Radio has an awful squelch tail and the software won't allow any adjustment beyond tail elimination.
