Can I read serial number via software or display?
KA7JUR
I am trying to find out if the serial number of a TK-5710 can be read via software or via the display in a test or service mode. A set of these got mounted in difficult places to see the serial number stamped on the cases, so I would like to be able to read the serial numbers via the control head display or software.
Perhaps somebody that is not familiar with the TK-5710 will be able to let me know if this feature is usually available on other commercial Kenwood models.
Thank you for taking the time to read this.
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
What ramal121 says is the best way I've found. If you get into a position where you can't read it with software (didn't bring your cable perhaps) and need the info, IIRC you can display the firmware info (and I'm hoping the S/N etc) by holding the orange triangle button while powering on. That applies to the TK-7180/8180, so I'm reasonably certain it will also work for the 57xx models. If that doesn't work, try A + power on - that's "panel test mode" which may provide information on there too. Of course, powercycle the radio to go back to normal mode.
