Can I stream DSDPlus AirSpy?
#1
I am wanting to know if there is away to provide a feed via DSD+ and Airspy? I got a pretty large county to my south that has its entire public safety on NXDN and I would like to provide a feed for it. Is it possible? If so I would like some tips on how to do this.
Thanks.
#2
You can. One way is to use "Virtual Audio Cable." It is cheap and very powerful. Just output the DSD audio to the virtual port and then use that as the input for your feed. It is a little more complicated than that but I have used it in the past for my own personal feeds and various other projects.
