Can I tap the 12v output of a UPS battery?
scanmanmi
Central Michigan
I have a UPS and I also need a backup 12v battery setup for a spare emergency rig. Typically I would have to plug a 12v power supply into the UPS 120v which would lose a lot of energy. What about removing the inverter portion and tap straight off the battery?
popnokick
Northeast PA
How much current do you need the 12V battery to supply and for how long? If it's a typical 100W RF output transceiver it's going to draw 20-30 amps on transmit. There are UPS with 12V outlet(s) but most of them supply very low current (less than 1A). You might be better off considering a separate 12V battery and charger to ensure the battery remains topped off. Safer than making internal battery connections to a UPS that has only 120VAC outputs.
a417
depending on the unit, taking power off the battery directly would be a load upstream of any built in current sensing circuitry of the UPS. Runtime will be unreliable and if you put enough of a drain on it, the circuitry might shut the entire UPS aspect of your device down due to what it sees as a depleted battery.
wa8pyr
Staff member
Lead Database Admin
Ohio
Your typical consumer grade UPS is only designed to keep your computer (or whatever) running long enough to give you time to save your work and shut down the computer, as well as cushion equipment against power line transients.
As others have noted, the battery in a UPS is typically too small to power your rig for any real length of time, plus you could screw up the UPS by tapping off the battery. Plugging a power supply into the UPS is also inadequate, not only because the UPS won't power it very long, but since you're converting AC to DC and back to AC again, it's amazingly inefficient.
Best bet... get a power supply and gel-cell battery suitable for your current requirements, and connect them to the rig through a gadget like the Flint Hills Radio Low-Loss PWRGate, West Mountain Radio Super PWRGate, or Astron BB30M. The power supply will power the rig and at the same time float charge the battery; if the mains power goes away, the rig will instantly switch to battery.
I've used a setup like this on my home station for years with a 33Ah battery and a Low-Loss PWRGate, and it works like a champ.
