Handhelds are great if you want to go to your local airfield, but if you want to listen from home then an outside antenna is much better - even so it's sometimes difficult to hear the ground frequency and aircraft on the ground too. Anything more than 10miles or so tends to be noisy. The high altitude ATC transmitters are often on high hilltops so you can hear them quite well.
