can someone add fremont ohio police
mciupa
DB Administrator
Moderator
#2
Hi amanda419, welcome to RadioReference :)
I had a look at Sandusky County and Freemont Police are listed there
Code:
453.82500  ( 173.8 PL) FREMONT PD  Fremont Police - Primary Dispatch  FM  Law Dispatch
Spotsylvania County, Va
#4
I dont see it on there anywhere
I will also add my welcome to Amanada. As for the information cited by MCIUPA, it is listed exactly where he indicated - if you look in the right place. Open the Database link at the top of the page. Then on the map of the US, click on Ohio. Under the map of Ohio that appears, in the section "Go To A County" (or roll your cursor over the map) locate Sandusky County and open it up. Then go to the section entitled Law Enforcement, and the 11th listing down in that section is the one indicated by MCIUPA.
Macomb, Michigan
#6
