can you run sweeper while scanning?
swm239
Hello, been looking through the threads and can't locate info on running the freq sweeper while you are scanning at the same time. Is there a specific setting to set to make this happen?
Thanks, Scott
ScannerSK
Gilcrest, CO
Thanks, Scott
Both cannot run at the exact same time. However, you can create a sweeper object and then the scanner will take turns between the sweeper object and your other objects while in scan mode.
Shawn
