SDRTrunk Can you stream a single Broadcastify feed straight from SDRTrunk?
far342
I see there's a streaming option in SDRTrunk, going to make a new stream the only Broadcastify option it shows is 'Broadcastify Calls'. If I were to stream a regular Broadcastify feed (not a 'Calls' feed), would I still select the 'Broadcastify Calls' to do it, or do I need to do something else?
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
Choose the Icecast V2.3 option for a normal BCFY feed, not Broadcastify Calls.
Enforcer52
Lake Livingston, TX
Go to Broadcastify, select the Broadcast tab, then choose Broadcast Feed, then choose Broadcastify Audio Feed. Once you fill in required info and get your login credentials then put that in the Streaming Configuration section.
