can you use Digital talkgrups on SmartNet
ssd
NEVADA
can you use Digital talkgrups on SmartNet? or dos it have to be szone?
N4DES
Digital on SmartNet is typicially an analog based encryption (DES,DVP,etc.). There is no true APCO P25 digital on Smartnet. On SmartZone you can operate P25 (Astro) digital and then it can be encrypted with DES/XL, DES/OFB, etc.
greenthumb
Colorado DB Administrator
Actually, P25 digital transmissions are supported in SmartNet so long as there are no consoles attached to the system.
WayneH
Forums Veteran
Super Moderator
Sitting in an airport somewhere
I concur, and I believe you can use consoles provided the system isn't Simulcast.
Travis AFB in Solano County, CA is a SmartNet system running digital.
