I've programmed (manually) this new system into my 996XT, but I'm not certain if I've done it correctly; I don't have much experience with true P25 systems. When holding on 143.76, line 2 alternates the site name with SID: 05DEh-0103 (when I'm getting good reception), but I don't hear a control channel sound (am I supposed to, or is that only on a Fleetnet type Motorola system?).
Two programming questions:
1. Is this system standard or one-freq trunk; and
2. Is it an explicit or implicit system?
I've programmed it as standard, and I assumed it was explicit. Additional programming/set-up notes for the way I set up this system in my scanner:
I programmed all of the control channels listed in the database for the Petawawa tower;
Delay is set to 0;
Hold time is set to 0; and
I've programmed the TGs listed in the database although the system is set to "ID Search."
Everything else was left as default settings.
Curious...now I have a third question. I was just double checking my settings; under "Edit Band Plan," which I had left blank, "0:" now reads 851.00625/6.25. The remainder of the band plan slots are still blank. What did my scanner do to the band plan?
I live in a spotty reception area in the outer-third of the tower's range, and I've yet to hear any voice tx's when the scanner is receiving the control channel. I'm hoping someone can tell me if I've set up correctly for good reception days and those days I have the scanner with me in Petawawa.
Thanks!
