Canadian County Pafford EMS
nd5y
Wichita Falls, TX
The db shows Pafford EMS in Canadian County using a DMR repeater on 155.94 with a license that belongs to the city of El Reno that expired in 2013.
This morning I heard somebody tone out medic units to addresses in El Reno on 153.635 DCS 712 which isn't in the db.
The repeater has a CW ID that matches https://www.radioreference.com/apps/db/?fccCallsign=WRDC920.
Somebody locally needs to verify and submit any corrections.
Turner101
They were suppose to be using the old mercy dmr channel for El Reno with other areas of their coverage using analog. Ill try to check and confirm when I get a chance. There is a thread on this already too.
