jwelsh793
I have had this issue on multiple occasions. After not hearing traffic from organizations for some time I manually scroll to the system and get the message every 2 seconds; "searching for control channel" and after a minute states that it is unable to find control channel.
To fix this I must reconnect the scanner and erase then load all channels again. I have not found any other complaints in the forums that resemble this. The only action I take is turning a system on and off by hitting the 0-9 numbers. Is there a way to prevent this from happening and if it does happen is there an easier way to fix this?
I am away from my radio and unaware of what firmware is currently loaded.
Thank you for your time!
