Can't copy .dat files to another computer?
dgruver911
Newton, KS
I have 2 identical programming laptops running the same software. I copied all the Kenwood FPU .dat files that I had saved from one laptop to the other, but the second won't recognize or open any of the files. You can see them in explorer, but for wahtever reason the Kenwood software doesn't see them. Ideas?
cabletech
Puget Sound
Where did you copy the files to on the other computer? Make sure you are looking in the correct location.
Copy your files on the new computer too: kenwood, kpgxx, data. Should have no problem
I transfer files between computers all the time with no problem
baycomm
Greenville, Delaware
Check the file names on the new computer carefully. If the files were manually renamed you may have ended up with double file extensions: "filename.dat.dat" If this happened, just rename them again with no file extension. It should default to a single .dat. We keep all our program files on DropBox so they are automatically copied to multiple computers-never had a problem.
dgruver911
Newton, KS
They were not renamed. These 2 laptops were purchased together and the software loaded on both; then the files were copied from the old laptop to both computers; from the data folder under each version of software to the data folder of the same version of software on the other computer. But one works and the other doesn't.
