Can't Edit Astro 25 Channel ID
Fireattack484
Midwest
#1
Running Astro 25 Mobile CPS, Version 20.01.00. Codeplug is for an Astro Spectra Plus W4 on 800 MHz. I need to edit the Astro 25 Channel ID field, but it is view only. I have a valid key loaded. Am I missing something? Is this field dependent on the correct settings in any other fields that I might be missing?
